pwrwagonfire
- 5
- 0
- Central Massachusetts
You did a great save...nice solid truck, it'd be a shame to have it scrapped! After your finding the old CD tag, I'm VERY curious to find out more history about this thing...
Interesting info. Hey - domestic pickups have crappy steel, who knew???Beside all the fun that might come up here with that truck. Fact is, as said before: it is a Gas engine, else no foot starter.
Second: The steel quality for European understanding is not very high, so welding is not realy the problem, for useually the welding material is of higher quality (except sulfor and posphor content). (Truck frames by that time had at its best a quality of 22000 psi steel, which here is a simple construction steel with no further requirements.)
If the welding is taken of without or almost without any ´trace on the frame, it was so called cold welding, means the electric current was not high enough to burn / melt into the frame. Basically this weld is not existend (We call someting like that a glued weld.).
Third: The frames are could bend, the material is heat treated before the bending / pressing in shape. This enlarges with the propper material the strength of the steel, especially with the quality used.
Buy the way, Pick ups are of only a 14000 psi quality, which you can not buy in Europe. 22000 psi steel is something like ordinary construction steel over here, called ST37 or nowadays Q285.
Wolf
Your gona like the smoooooth sound of that gasser. Good save and fun with her.
Yes it is!!!!!! the pto lever is next to my right foot. the lever on the pas side engages the front drive.Tigger that lever is not for 6x6 drive like srjeeper said it's for PTO that was on the truck at one time the wheels engage into 6x6 when the rear wheels begin to slip then the front axle was positively engaged by the sprag unit and it would kick in and you would have 6 wheel drive .![]()
I believe that the first post said that it has a REB kit , if it does it has to have a SHIFT LEVERYes it is!!!!!! the pto lever is next to my right foot. the lever on the pas side engages the front drive.
The Fire dept that had it before me had the reb kit put in it. i think is is a better idea but thats just me. hope it don't break , i understand they don't make them any more!I believe that the first post said that it has a REB kit , if it does it has to have a SHIFT LEVER
I wonder if someone who had reb kit, pulled it, took it apart, and then see what it would cost to reproduce it, if there would be a demand for it, I would think the sprag deuce owners might find this route better then installing a air shift
Looking at the parts book from Memphis Equipment, the sprag was replaced with a gearset.I believe that the first post said that it has a REB kit , if it does it has to have a SHIFT LEVER
