Gasser Into Mulit-Fuel
1,827
Not too hard at all. Some labor involved. Transmissions will end up in the same exact place so that is a non issue. The actual gasser tranny is identical outside to the one from the multfuel. You will need to move and add some fuel lines, add a lift pump of some sort and change the RR frame mount as well as the front engine mount crossmember.
If you want to get an idea of the process, check out what this fool did!
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=4163
