2deuce
- 147
- 63
- portland, oregon
I have a 1953 Gasser that I'm trying to get road ready. It has a lifter noise problem that comes and goes about every 15 seconds. Oil pressure on the gauge reads 40lbs. Anyone dealt with this before? It does this at idle. I can't hear it in the cab so I'm not sure if this happens at higher engine speeds. It sounds like its comming from the rear valve cover. This is the R6602 engine it sounds beautiful between the noise spells. The noise comes on gradual and leaves gradual.
Greg
Greg
