gasser parts
BFR
Rocket Surgeon
2,330
42
North Georgia
I will be "disposing" of a 1952 REO M45(cab & chassis) w/w.
All parts except the winch components and the front spring hangers are still available. Cab/doors are beyond repair.
any interest?
Engine runs, has a significant rear main seal leak
transmission(3052) shifts, had water in it when I drained it
transfer is a sprague
fenders and hood are in decent condition
grill is nice and straight except one of the crossbars under the headlight(easily fixed)
shadow
Cedar Rapids, Iowa
I have an old Reo. I might be interested in some parts. Does anything off a M45 fit a M275 ?? I can't find a picture of a M45 online so I am not sure if they are the same type of truck or not.
The only thing I could find out between the 2 is:
M45 Chassis, truck, REO AO331, 2 1/2-ton, 6 X 6, 9:00 X 20 tires
M275 Truck, tractor, short whbs, 2 1/2-ton, 6 X 6, (M35 series)
Please forgive my stupidity on this.
My wish list of parts are:
I am looking for some rear lights (I don't have any),
front window glass (mine are bad)
seats (mine are tore up)
mirror mounts (mine are from a mac truck and small)
sending units and/or gauges (I don't think any of mine work)
carb for gas stright 6cyl engine (mine never likes to restart after sitting)
tires 9.00, 10.00 or something better then 8.00 that is on there now.
Crazyguyla
124
Altus, OK
Joel,
My list is long, I'll PM it to you. How long is the truck going to be around before disposal? I'm sure some of the stuff would be easier for me to pickup rather than ship.
BFR
Rocket Surgeon
2,330
42
North Georgia
a M45 is essentially a M35 without a bed.
-I have the rear lights but have never attempted to get them working. IMO I would go with the newer style unless you are goal is an accurate restoration.
-I swept the windshields out of the floor when I got the truck
-seats are trashed in this one as well
-mirror mounts broken
-the batt/gen gauge works
-fuel gauge appears to work, but sender is bad
-air pressure gauge works + low air buzzer
-speedometer w/12XXX miles works
-for now I would prefer to leave the carb on the motor in case someone wants them both, but I got a rebuild kit for it from sarafan.
-I have several tires in the 50-55 age bracket, but trust me you don't want them
1,158
master cylinder cap? Need to build a bleeder, didn't remember if I mentioned this last night.
Spring ride? rofl just checking rofl
extra air motor for wipers?
Good winshields?
Extra pintle for my front bumper to jockey 105's around?
1,824
Clinto, you waqnt a deuce pintle or a little 4 bolt one for backing? I've got a deuce pintle with brackets on the floor! Need it, I'll bring it!
Crazyguyla
124
Altus, OK
Joel,
My PM is acting wierd, anyway, here's my wish list
Front Bumper w/ gussets
Rear wire harness
hose from air monifold to air gage
hose from fuel pump to frame
windshield frame
parking brake handle and mounting hardware
floor panel over transmission (center section)
fuel tank
I'm sure there is something else i need..
BFR
Rocket Surgeon
2,330
42
North Georgia
Ok guys I have made a list of who asked for stuff in order. I do not know what to ask for it so make offers... I am more than open to trading stuff. I am most definately not a pro so this stuff will be pulled gradually over time. If you need something in a hurry and I will do my best I hope to have the truck broken down and the leftovers taken to the scrap iron yard by Thanksgiving.
BFR
Rocket Surgeon
2,330
42
North Georgia
Here is what I have you down for, if you don't want something or want something else let me know. send offers for the bits you want. Remember trading parts is just as good if not better than $$$ to me.
FWIW I am looking for clearnace lights and heater ducting if you have any lying around.
M45 Cue
Shadow…
rear lights
(see earlier reply)
Crazyguyla…
Front Bumper w/ gussets I have a serviceable set (does not include any winch brackets)
Rear wire harness (appears intact, but it is 50+ years old)
hose from air manifold to air gage (it is there, but leaks)
hose from fuel pump to frame (all I have is the one I made up out of stuff from NAPA)
windshield frame ( I'll have to get you some pics)
parking brake handle and mounting hardware (there, but seized {rust})
floor panel over transmission (center section) in pretty good shape very attracive shade of yellow
fuel tank (in good condition)
Clinto…
Good winshields? (you are not right :cookoo: )
Extra pintle for my front bumper to jockey 105's around? It is already gone
Sermis... spring hangers etc from front
1,158
I know it sounds crazy (such a small item) but I need an "8" for my bridge plate # collection.
Crazyguyla
124
Altus, OK
Re: RE: gasser parts
M45 Cue
Shadow…
rear lights
(see earlier reply)
I have 2 brand new composite rear lights
i know i have a couple gauges lying around, just not sure which ones.
M45 cue???
Crazyguyla…
Cool, sounds good :D since i'm missing a bumper
it probably looks better than my harness, mine looks like some huge rat ate it
Mine's MIA.. better leaky than none.
MIA too
It has to look better than mine ;)
nothing wd-40 or such can't fix ;)
yellow's good ;)
That's better than mine.. unless of coures fuel tanks are supposed to resemble swiss cheese
By the way, I could use the hood too.
:nothingfunny:
When I go down to Louisiana next month, I'll see what goodies I have stashed inside my truck.
rmgill
14
Decatur, Ga
RE: Re: RE: gasser parts
Do the gassers have air or electric horns? I have a mind to tap in a second horn set and run those from the air solenoid. I have some Every Thursday anti-war protesters I want to give a Honk at. And since I don't have an easy source for Nathan K5s....
rizzo
Port Huron, MI
Re: RE: Re: RE: gasser parts
I think the horn on my M543 is very loud. The one on my deuce doesn't work so I can't compare. they look the same. are they different?
BFR
Rocket Surgeon
2,330
42
North Georgia
RE: Re: RE: Re: RE: gasser parts
my gasser has air horns, unsure of whether or not they work(they look pretty good)
BFR
Rocket Surgeon
2,330
42
North Georgia
radiator holds water, have new uninstalled radiator hoses and oil filters.
BTW I also need some mudflaps (metal and rubber parts)
