Gasser
rflegal
11
New Mexico
OK guys, so I have a fairly rare M36 longbed, but its a gasser, OA331 6 cylinder. Is this worth hanging on to? Should I swap in a diesel? Should I unload it and look for a newer M35A2 with a diesel? Thoughts...
Buy the way, cranked it up, runs good, sounds OK but might need the tappets adjusted. Anyone have the TM # or a copy for servicing the OA331?
Thanks for the help, love the board.
Bob
Desert Rat
Bob,
She's a keeper in my book. I'd be tempted to convert to a multifuel for many reasons. A biggie is being able to use filtered used motor oil as a fuel and cutting the costs of your fuel bill waaaaaaay down, parts are easier to find for a MF, more horsies, I can go on and on and on like the energizer bunny............
JasonS
139
Eastern SD
The reo is a good engine. I converted mine to full flow oil filtering and have a converted mini hei distributor in the works. I bobbed my truck so horsepower is OK. Be even better once I fix a dragging front brake.
Desert Rat
Jas,
Brakes can be a drag alright! It's when they catch fire that you REALLY have a problem on your hands.
JasonS
139
Eastern SD
I am still at the smoke stage but I limit myself to a couple of miles. The shoes are adjusted as loose as possible but still drag. Probably due to a leaking wheel cylinder/shoes swelled up. It may be tough to get the drum off. Any suggestions greatly appreciated.
I have the military and civilian manuals for the reo engine. I also have a brochure finely detailing the engine construction and materials if anyone is interested. Horsepower aside, the reo is arguably a much better engine than it's contemporaries (gmc 302). Good design and good materials. There was also a 440 cubic inch V-8 version of the gold comet six with 225 HP. An article in Rod & Custom in 1955 suggested that the v8 would make a great hot rod engine but the weight >1000 lbs was an impedimant.
