Gauge Lighting
blue302stang
Flower Mound, Texas
I replaced the non functional water temp and oil pressure gauges in the dash with autometer gauges with a white led backlighting and it got me to thinking of a possible way to improve the lighting on the stock gauges. I found a seller on flea-bay selling pre wired leds set up for 24volt. So my question is if it is possible to drill a small hole in the back of the gauges and put the LED in there to create a around the bezel type illumination? The cover is missing over the bulb for the gauges, so instead of making some sort of cover for the bulb i figured it would be easier to try the led method
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Have you tried cleaning the dust off the side windows of the gauges to let more light in? How about the shorter bulbs someone posted up?
Castle Bravo
Hundredaire Socialite
218
Arizona
A #356 bulb lights it up real good. Its a drop in fit and they're not very expensive. I rarely need to turn mine to high, the low setting with the #356 bulb is typically sufficient.
blue302stang
Flower Mound, Texas
The 356 bulb seems like an easy enough way to do it, but i have the two autometer gauges running leds and love the look of it, so was trying to hopefully find a way to do that with the stock gauges as well.
59apache
Chipmaker
1,299
29
Bavaria / Germany
Here is a thread from another Oklahoma SS member (mikew) who added LED lights to the stock gauges in a bobbed deuce he built. I actually got to see this truck in person and it was really nice! The craftsmanship and attention to detail were just incredible.
http://www.steelsoldiers.com/deuce-modification-hot-rodding/47558-yet-another-way-bob-deuce.html
i find these 24 Volt Orange Truck Trucker LKW SMD LED Strip 24V | eBay
LED stripes.....they are 24V! They should also availible in the US.
With LEDs keep in mind, they are voltage sensitive. Some have a built in voltage stabilizer, some not.....and with 28V they have a short livespan.
maybe you have to use an external stabilizer.
nk14zp
17
Columbia Falls Maine
I use LED................................................................................................................................flashlights.
cyruscat
Arkansas
I followed curryra's method with the flexible LED lights and it works great.
Bought them at Wally World in the auto customizing section, $14 for 2 ea. foot long strips. Light up blue in color, cut off original wires from gauge lights and wired in the LEDS. Wrapped strips around gauge windows and taped/wire tied in place.
Most LEDs dont care what voltage you feed them, researched before hand and found that small LEDs like these will operate from 2 - 48 volts without damage. Just varying brightness.
Hardest part of job is disconnecting speedo and tach cables so you can lay the gauge panel out for access.
