Gauges
tlarkin530
Phoenixville, PA
The temperature gauge in my '67 M35A2 is bad. I'm not 100% sure if it's the gauge, the sensor, or both. Where can I get a complete setup (sensor, cable, and gauge)? Thanks!
simp5782
Feo, Fuerte y Formal
9,327
Mason, TN
Or just get a mechanical water temp gauge kit from a local autoparts store. Just put the fitting in on the side of the intake manifold.
1,172
Or fix it correctly by diagnosing the issue. It's all listed in the -20 TM. Just need an ohm meter and a few minutes time.
WillWagner
2,532
Monrovia, Ca.
:ditto: What he ^ said. Why do you think it's "bad"? Better spank it if it is and maybe it won't do what it did to be bad again :razz: Sorry, I am used to warranty. Not bad, failed...how is it failed?
houdel
9
36
Chase, MI
What he said. These things are very easy to diagnose. There are very detailed step-by-step directions in the troubleshooting TMs. Much easier than randomly swapping parts.
More often than not the problem is a bad electrical connection or a bad ground, neither of which you are likely to fix by replacing a guage or sender.
As for replacing the "cable", it doesn't work that way. The wiring for the temp gauge is part of the wiring harness, not a separate part, and there is seldom a problem with the harness itself unless it has been damaged or been screwed with by someone.
BTW, here is the link to the TM which contains the electrical system troubleshooting instructions. Good Luck!
http://test.steelsoldiers.com/upload/M35/TM9-2320-209-20-2-2.pdf
