The little fluorescent needle that tells you what gear you are in wasn't working. I took it out and cleaned it so it moves back and forth freely in it's bracket.. I put it back in and the metal clip back on the steering column. The cable is off the end of this column, rather than riding on it's circumference. Looks like there should be a second metal clip but the book doesn't show one. Can anyone tell me the correct routing for the cable and clip?
