MIKE2A6X2
- 1
- 0
- SOUTHWICK, MA
Does anyone know where i could get some higher gears for the differentials?
What Allison?
Ummm.... yeah.4,5,6,8 Speed automatic.
Was manufactured by GM, Detroit diesel,Allison div.
Tom
The conversion flange yoke/u-joints available to adapt the 3053A output to the M37 short shaft are the way to go... and correct on the need to fab a rear trans mount for the 3053A - it's a heavy trans, but not that much more than the weight of a NV4500 & way cheaper on the required transmission lube.M35Tom also has a taller overdrive kit for the 3053 Spicer's.
I put one behind a 427 tall deck Big Block Chevy in an M715 and ran it for years that way. It's a good trans for a lower buck swap but you will have to get creative for the rear transmission mount as stock they were suspended from the bellhousing. I made one up on the M715 catching a couple lower output collar bolts and bracing down from the top cover. Everyone knows that truck certainly was put through some tough terrain. Also you'll have to make a custom jackshaft from trans to T-case. Smallest you can go (that I'm aware of that bolts up) is a 1410 on the 3053, then reduce that to a 1310 which is prolly the size of your T-case yoke as it was on the original NP200 in the truck before I swapped in the NP205 with all 1410's.
