HikerLT said:
Newbie question here- How would you change the M1008 gears so you get better highway speeds..? Would you have to change both the rear and the front differential gears ?
You could change the gears, but it'd slow down the truck and really hurt it's pulling power. The TH400 has a really high first gear (2.4
and it really needs the lower gears for any sort of torque to the wheels. And yes, you'd have to change the front and rear gears, or forget about using 4WD. I have been told that the next ratio that the Dana 60 and 14-bolt have in common is 3.73 (at least commonly available) and I sure wouldn't want that.
For an easier "gear swap" you could try larger diameter tires, but that has all the negatives of the gear swap (except cost/time) with the added issues of reduced range of motion for the suspension (and/or need for a lift to get more clearance).
That said, a better idea would be a 700R4 swap- you'd win on both ends, getting a lower (3.something) first gear on the low end for more stump/trailer pulling and load hauling ability and an overdrive on the top end.
As I see it, the flaw is the TH400's gear ratios. It's a rock solid transmission, don't get me wrong, but it's really not the best choice for the job, especially with the 700R4 available.
rfischba1 said:
Is the rear with the 4.56 gears the reason it feels like my M1008 is always still in 2nd gear?
Seems like it never upshifts to a higher gear?
I don't know, does it shift to third? Pretty easy to tell, but yes, third comes pretty early 20mph if everything is working good, I'm up around 38 because of a minor vacuum leak) so sometimes it'll feel like it should shift again (and, if it were a more modern truck with an overdrive it WOULD shift again), but to answer your question, yes, the fact that you run out of gear below 70mph will sure make it feel like it's in a lower gear than it should be, and yes, that's because of the 4.56.
