- 7,390
- 2,437
- 113
- Interlachen Fl.
First of all why do the let someone that does not know what there doing work on the axles.
Thanks to Steve I started digging into the front end. Right side was looking ok but drivers side had fine metallic tint to the oil. Here I found the so called mechanic left out the thrust bearing washer. The cap has some damage and the side gear has some wear plus a good nick in the face. Thrust bearing bad to. New thrust bearing and washer in pic. So I will take the bad cap and cut off the face and use it as the cross retainer to measure the correct gap on the gears. Thanks again Steve 6x6x6.
