Geared hub input seal retainer shims
DatGuyC
22
Essex, Maryland
While removing the retainer to replace the input seal I broke the shims that were behind the retainer. I ordered new ones from kascar but the ones I ordered seem thinner than the ones I took off. Also the new ones are clear while the old ones are a solid brown. I'm wondering if there are different shims for the hubs and if they are indeed different thicknesses. There were 4 of the brown shims on the hub, where I hear most only have one or two.
Retiredwarhorses
4,632
Brentwood, Calif
They have them is different sizes...you add them to the correct tolerance so the plate does not over tighten the upper spur gear once the 4, 3/8 bolts are torqued. The TM has the procedure.
if you get it all torqued and cannot turn the spindle somewhat freely, it's too tight, too loose, and...well, to much play.
your supposed to use a feeler gauge to set them correctly, you could micro the old shim and just try and get the same thickness from the new shims....I do use A thin film of RTV on the seal plate and hub surface...this will prevent seeping..IMHO.
