Gel batteries
mbwarner
Milton-Freewater Orygun (NE)
The M35 I picked up last week came from Air National Guard with two auto type gel batteries.
These two batteries from 1997, and crank the engine beautifully and hold a charge well.
Are others having this kind of extended service life from gel batteries?
cranetruck
75
Meadows of Dan, Virginia
One feature of the gel cells is that the self discharge rate is lower, so if the batteries are charged reasonably often they won't sulfate, which sets in when the voltage drops. Also, if kept cool, batteries will last longer.
1956_4x4
Crestview, Florida
I used to have problems with lead/acid batteries shorting out in the front-end loaders when I was in the service. These loaders would spend 5 days per week doing their bit during rapid runway repair. This repair was being done as different CE units were evaluated on their war-time capabilities, so the loaders were shown no mercy by the operators. I'd be lucky if I could keep batteries in the loaders for 3 weeks. I started switching the batteries to red-top Optimas and the battery problems disappeared.
They're good enough that I put one in my '56 5 years ago. No problems yet...
Smitty
EO2NMCB
22
DeSoto, MO
Well its good to hear that you all are having good luck with them, I didn't fair as well with a set of 4 decka's in a road tractor, only lasted about a year or so. Went back to the lead acid and all is well.
area52
San Bernardino CA
I bought my 88 Jeep Comanche back in 2003 and the previous owner had put a red top Optima in. Not sure how old it was when I got it, but it has fired my 4.6 stroker up without fail for more than 5 years now.
