soldierman79
- 0
- 0
- San Antonio, Tx
My GEN 1 light came on while driving the other day. So, I rebuilt it with an alternator rebuild kit that I had from cucvelectric.com and cleaned off the electrical contacts.
GEN 1 light still stays on.
Each battery checks at ~12.5 with the vehicle off. While running, rear battery is at 14.4, front is still at 12.4, front isn't charging.
I followed the below diagnosis from the 'CUCV Alternator Symptoms, Diagnosis and Fix' Thread.
I have posted ignorant questions in the past and got the 'Use the SS Search' response. Well, I have been searching, a lot. I'm still searching.
Any knowledge or insight will be greatly appreciated. Thanks y'all!
That all checked out fine with my alternator.Each alternator is a 12 Volt unit. The big red wire that is bolted on has 12 volts from the battery. The little white plug has 2 wires on it. The thicker is the voltage out of the alternator back to the battery. The smaller wire is the exciter wire.
With the engine off, the big red wire should have battery voltage, so should the bigger wire on the plug and with the plug off, key off, the exciter wire should have nothing.
Turn the key on and the plug off, the exciter wire will have battery voltage along with the other 2.
