Gen 1 light and voltage issue
alburms311
Hayden, AL
I have a few issues. Issue one, so when I start my M1009 the Gen 1 light stays on, sometimes, however, it will go off after pressing the accelerator lightly. Reading through the TMs I'm thinking I need to adjust the idle speed, however, I'm not sure how much to adjust to get to the called for rpms. I read in another post I found on here that this was common, does anyone else have this issue?
Issue two. On start up, my volt gauge reads right in front of the tick mark in the green, after about 45 secs-1 min it goes to the far side of the tick mark in the green, and after that, usually after high idle has gone down, it moves to the line between green and red(see pictures) and stays there while driving, never goes any higher. I tested the battery's(see below) and I don’t believe I’m over charging. I had to go last night before I got a chance to test the alternator or volt gauge but I’m thinking that’s my next step hopefully this afternoon.
Side note: Gen 2 had been rebuilt and was sitting in drivers seat when I purchased vehicle, Gen 1 I have no history on, so I'm thinking it wont be a bad idea to order the rebuild kit from CUCV Electric. And here's a picture of her painted green, Ill get to the wheels shortly.
Any thoughts or suggestions?
Battery readings:
Bat 1 off engine cold: 12.78
Bat 2 off engine cold: 12.79
Bat 1 high idle lights off: 14.74
Bat 2 high idle lights on: 14.93
Bat 1 low idle lights on: 14.74
Bat 2 low idle lights on: 15.34
Bat 1 after running idle 15 min lights on: 14.69
Bat 2 after running idle 15 minutes lights on: 15.31
cpf240
Free in Northern Idaho
Yes, you have to bump the throttle to get the Gen 1 light to go off. This is normal. As for the voltmeter readings, this is probably due to the cycling of the glow plugs and their "after glow" cycle.
alburms311
Hayden, AL
Thanks for the response cpf240. So, do you think the reading on my gauge in the picture is fine(the last pictureof it), or does it need to be investigated further?
cpf240
I think you are fine. As long as the charging voltages measured at the batteries are within spec, it should be good. My volt meter reads just over the line into the red, which would indicate an overcharge condition. However, measuring the voltage at each battery shows it is fine. One thing to keep in mind is that the voltmeter in the CUCVs is a 12v gauge, with a resistor on the back of it to drop the 24v it is fed down to the 12v range. That resistor could be out of spec, or the gauge could be.
Use the voltmeter as a guide, but verify with a DVM at the batteries.
Have fun!
