cliffyp
- 4
- 18
- Brownsville, Texas
My Gen 1 light has always come on at start up and would go out as soon as I gave the accelerator a little juice, or if I started with half throttle it would go out immediately.
I'm sure it's unrelated, I changed the oil with my 3 year old. He wanted to work on the truck with daddy and it was due anyway. After we finished, I cranked her up. Everything normal, both Gen lights turn off when it starts up. I leave it idling to come up to temp. A few minutes later I hop in the cab and Gen 1 is lit up.
I check the TM.
I don't have the means at the moment to check idle as #1 calls for, but it sounds normal. Rev the engine or idle, Gen 1 stays on. Proceed to step #2
I disconnect the connector from Gen 1, lights out, so I guess I'm tracing a circuit over the weekend although I'm guessing my alt just took a poop.
Anything else I should be checking or should I just go ahead and order a rebuild kit from CUCV Electric?
I check the TM.
