Both GEN lamps light at start up- GEN 2 lamp went on during a drive yesterday- and stayed lit. Been getting readings this morning:
I could use some input here on my results, please.
I just noticed that the front passenger side plug wire had come off of the glow plug- as I remember: Yesterday on the freeway, when the GEN 2 Light came on I noticed a miss developed. I'm heading back out to see if the failed connection caused the GEN 2 Lamp to light up???
Do both GEN lights come on when you turn the key to RUN? YES
Is you truck wiring bone stock or has it been modified? No resistors when purchased- otherwise stock (Doghead relay done)
Remove the 2 pin plug from the alternators and check the voltages. Fill in the blanks.
GEN1 - drivers side
key OFF
small red wire - 12.5 volts
small brown wire - 0.0 volts
Key ON
small red wire - 12.0 volts
small brown wire - 11.9 volts
GEN2 - passenger side
key OFF
small red wire - 12.4 volts
small brown wire - 00.3 volts
Key ON
small red wire - 12.2 volts
small brown wire - 11.8
How do the plugs look? very dirty? corroded? Not checked yet
Battery Voltage - check at the battery terminals of each battery. Don't use the truck for ground.
truck off
front - 12.4 V
rear -12.3V
truck running
front - 14.3V
rear 12.2 V
Batteries: Across both: 26.5 Running/ 24.7 IGN OFF
Rear Batt 12.4 OFF
Frnt Batt 12.3 OFF
GEN1 - drivers side
key OFF
Key ON
key OFF
Key ON
truck off
front - 12.4 V
rear -12.3V
truck running
front - 14.3V
rear 12.2 V
Rear Batt 12.4 OFF
Frnt Batt 12.3 OFF
