Trailhead 4x4
- 0
- 0
- Cleveland, Ohio
so I guess I'm still chasing charge problems on the 1028. I got gen 1 working by cleaning all the connections and terminals and getting the belt installed and correctly tensioned, but now only a few days later I'm having Gen 2 issues. It has always required just a light tap of the throttle to get it to charge when starting up cold, and it still does, but now as the engine warms up, the Gen 2 light will come on at idle. At first it takes a while to come on, maybe after a minute or so of idle. As I drive more, the amount of idle time to cause the light to come on gets shorter until by the time I'm at work, the light is flickering on and off randomly as I drive. If I let the truck sit for a bit, it will charge normally again.
I do have a Banks turbo on the truck, and it sits very close to the alternator, could the excess heat load from the turbo be affecting the alternator performance? I'm going to look into building a heat shield, but i'm thinking the damage is done and it needs to come out to get rebuilt?
Both batteries are new, I've swapped their positions with no change in operation. All connections and grounds were cleaned during my battle with Gen 1. Thanks in advance SS!
