gen1 and gen2 bulbs
1,178
Nope
cucvrus
10,427
Jonestown Pennsylvania
I know they make a resistor to put in truck tail lamps so the ECM can send the correct flashes per minute when LED's are applied. So I do not see why you could not get a resistor in the circuit to make it work. I am not sure of what your gain would be by having LED idiot lights. I would see no benefit but it is possible to make it work. But is it worth the effort? Good Luck and report back. In today's world if there is a will there is a way. You just need to get with a person that knows electrical systems better then I do. That will be simple because I am at electrical 101.
cpf240
Free in Northern Idaho
LEDs are Diodes.. current only flows in one direction. It is my understanding of the GEN light function that current needs to flow in both directions... on way to light the bulb when the alt is not charging, and the other way when the alt is over-charging. The lights go out when the system is 'balanced', or near enough that the bulb isn't bright enough to see.
richingalveston
120
galveston/Texas
I thought the gen 1 light could be changed but the gen 2 light cannot. And the reason it cannot is because it has to have two way current flow. but I thought gen 1 was a regular circuit that could light an led.
I may be wrong so I am throwing this out there to be corrected if so.
Rich
