General Questions
Rebelpride
Thomasville, NC
I am going to pick up my M35A2 next monday (1/7) and was wanting to take an air hose to air up my tires from the fitting under the dash. And wanted to see pics of how to rig it up.
Also what precautions do I need to take when airing my tires, I have heard that these split ring wheels are dangerous.
Also I'd like to switch to Super Singles, I'd like to trade all 11 of my stock wheels for 7 M35A3 wheels with tires or another rim/tire set that would work. (Would that be an even trade or get me laughed off of the site)
Or if not trade what radial tire can I run on a stock wheel with flipped hub that will be wide enough not to look goofy
ida34
36
Dexter, MI
That kind of trade will get you laughed of the site. Good luck on finding the A3 wheels. If the rums are seated then airing up should not be dangerous. If any of the split rings look like they are coming out then do not put any air in those tires. If the rings and tires are seated fine then there should not be too much danger. The danger comes then you are changing tires and seating the tires and the rings. There is not much to doing the air hose install. Take a quick connect and put in ton in place of the pipe plug under the dash. You could also get a glad hand and attach the hose to it. You would use the emergency side as it supplies air all the time.
m16ty
227
Dickson,TN
No need to worry about airing up back tires with them on the truck. The ring that can come off and kill you will be on the inside so if it comes of on either dual all it will do is hit the other tire. The front is a different story. If they just need topping off, I myself wouldn't worry about it ( I'm not saying this is safe but I do it all the time). If the front is completly flat I would take it off and put a chain around it or use a chuck that will hold onto the stem where you can stand clear.
CliffW
Mims, Florida
You can pick one of these up at any truck stop for $25-$30 and hook it up to your glad hand at the rear of you truck. If I remember right you have to use the one on the passenger side to have constant air.
Hope this helps.
Cliff
M1075
Oklahoma City
I agree with using the gladhands. If you have a hose like shown above, you will not need to install or modify anything. It will be ready to use on your deuce or any other vehicle with an air system (military or commercial).
If you get a clip on chuck, you can safely air up your front tires while controlling the air supply from the gladhand valve at the rear of your truck.
The A3 wheels are HARD to come by. Good luck finding anyone who has 7 of them and then don't be surprised to pay twice what your truck cost you. Seriously!
In my opinion there is no suitable tire to be used with stock rims in single configuration. Keep it duals or go with new rims for super singles. M135 rims are also an option if you want to run 11R20 or 12R20 singles.
rosco
32
Delta Junction, Alaska
RE: Re: General Questions
If you don't find one of the air hose assemblies pictured above, be sure to note the long double ended metal tire chuck on the end of the hose. You need that kind to air up the duals. The tire guage to check the pressure should have a similiar end on it. I would have some extra valve caps, valve cores and the tool to install them. Maybe your lucky, but sometimes when tires have be sitting a long while & you go to check the pressure, the valve core will leak. The air fitting under the dash, right side, I believe is 1/4" MNPT. (Male national pipe thread).
If your thinking your going to drive your new ride home, be sure to take along a pretty good tool box. No telling what your going to find!
Lee in Alaska
oilcan
Ohio
If you go with the glad hand, make sure you grab an extra seal or two. They're only about a buck each.
1,161
:ditto:
alphadeltaromeo
Alto, GA
Gladhand and rubber seals are easily available at a NAPA, etc.
Also, you're in NC...we have members in NC that may be available to go with you to recover it. Why not post a request and see what you come up with? It's always nice to have some experience with you on the trip...plus it's fun.
