PowerstrokeNC
- 1
- 18
- Greensboro, NC
Ok, so I have researched all the generator adjustment options, I have found the allen capped grub screw that looks like the one I remove to get to the adjustment pot..correct?
But on my M923-A1 the oil cooler is in the way to get a screwdriver in the opening to turn the pot screw.
So my question is, for you guys who adjusted yours how much did you turn the screw?
I will need to remove the v belt and mounting bolts on the genny to rotate out the top of it to gain access to the opening, so by knowing how much to turn for x - result will help, reduce my number of R&R's to get the right setting.
Thanks in advance for the help.
