Generator not starting right
Afternoon
One of my coworkers has an issue with a MEP 802A generator. He describes it like this. Cranking and starting but half the gauges not working. Pulled voltage relay, checked, swapped. Now generator will crank but no start. He rechecked all the other relays, all are good. Any help be appreciated
Digger556
823
Denver CO
Afternoon
Did he mean voltage regulator?
Multiple things not working at once usually points to a ground issue.
If he swapped a component and now it won't start, there is a good chance he didn't put it back together exactly the same way.
