mangus580
- 284
- 0
- Western NY
[FONT="]Generator InterLock Kit[/FONT]
You have my attention, sir. Please, do tell me more about this diesel genset cooling loop to hydronic radiant floor heating connection. What do you do in the summer?And for those that are 'off grid'- go liquid-cooled, and remove the radiator. Instead, run the coolant into a heat-exchanger, transport this waste heat to your hydronic radiant heating system.![]()
That is not necessarily the case. The permit requirement is dependent on what state you live in. The only time I am required to pull a permit is for a service change. If i'm only adding circuits, or doing minor modifications there is no requirement to pull a permit. Heck, I live way out in the country, I built my garage (28x40 with a full 18x8x40 loft above in a gambrel roof), by myself, wired it, and then moved the 100 amp main service from the house to be a sub panel out of the new 200 amp main service in the garage and never pulled a permit or got any kind of inspections done. My Co-op electric company didn't even come out to inspect the service change, they just sent the linemen out to do it one afternoon. I was without power for a grand total of 5 minutes that day (long enough for them to walk the meter from the old base on the house to the new base on the garage and reinstall it).AN/ARC186 said:Just a reminder, ANY modification or addition to a residential electrical system requires a permit and inspection. adding a new gen input breaker, interlock device and associated wiring and devices falls into this
You are lucky. I have to a certain type of probe in the rear area if I even mention electricity in the Dayton area. Now I find out I may have to double the size of my underground cable because the 200 amp cable isn't large enough for a 200 amp service. Even better, you have to put a light outside the entry way door to the barn with the switch on the inside so you can get in after dark.That is not necessarily the case. The permit requirement is dependent on what state you live in. The only time I am required to pull a permit is for a service change. If i'm only adding circuits, or doing minor modifications there is no requirement to pull a permit. Heck, I live way out in the country, I built my garage (28x40 with a full 18x8x40 loft above in a gambrel roof), by myself, wired it, and then moved the 100 amp main service from the house to be a sub panel out of the new 200 amp main service in the garage and never pulled a permit or got any kind of inspections done. My Co-op electric company didn't even come out to inspect the service change, they just sent the linemen out to do it one afternoon. I was without power for a grand total of 5 minutes that day (long enough for them to walk the meter from the old base on the house to the new base on the garage and reinstall it).
This is clearly a case of the person behind the desk not having a clue. There's an entire section in NEC which covers subjects like 'temporary power' and 'unattached services', wherin a weatherhead on a pole feeds a meter and panel, which is then distributed. Agricultural services have predominantly been, and currently remain of this type... a meter-pole in the middle of a lot, with power coming to it, and then a main switch/breaker, with overhead feeders going to farmhouse(s) and outbuilding(s). This is the most common agricultural service setup, and farmers with auxiliary generators oftentimes mount the generator feedpoint here, too!only to call AEP and find out that they will NOT run a main service into an unoccupied building. The main service by them must go to the house first.
I have just two word....."Arc Flash...."2009 is bringing many unpleasant changes to all aspects of the code, especially if you're building a new house.![]()
You're absolutely correct- there's no preventing any level of authority or service from applying their own restriction or regulation. Not installing on a garage seems like an asanine rule- I frequently see lots wherin only a garage or non-residential building sits, and electric power IS provided there... and furthermore, if a gent has a house with 200A service, and wants a separate 200A service to feed his garage/shop, shouldn't he be able to be a customer there too?The utility companies don't give a rats butt about what the NEC says other than if the installation meets code or not. BUT that still doesn't mean that they can't have there own rules and regulations for hooking up a service. This installation clearly violates the utilities rules. ....it's just one of AEP's rules around this area to not install a meter on a garage.
