deuceman51
- 9
- 18
- Scotland South Dakota
How would you guys rate the red oxide primer that gillespie sells. Is it as good as rustoleum primer? Has anyone used it and had bad results with it? I have been stripping off yellow paint from my deuce and then I am going to sand the parts and was planning to shoot them with probably 3 coats of the red oxide primer. The only thing I want to make sure of is that this primer holds very well and doesn't start to flake or not bond to metal or paint well. Any input on this would be appreciated. Thanks.
