Giving humvee a service need advice
theman10k
London
Hi guys
Im doing an oil change on my humvee and need to know what oil to replace it with??
What type of oil and fuel filter do I need?
What Glow plugs are the best?
4,695
15w40 diesel rated oil for the engine. You'll need 8 quarts. For the filter, you have a few options:
Ac pf35
champion lab ph1218
fram hp4
fram ph13
fram ph5
mobil1m1302
motorcraftfl12
purol30040
purol34631
purol35132
wix51060
wix51061
Now for the glow plugs, do you have bad ones? Have you ohm'd them to check them? HMMWVs use 24v glow plugs that are specific to the HMMWV. (GM and CUCV 6.2/6.5 glow plugs are 12v)
Present conflict vehicle TM's can be found here:
http://www.steelsoldiers.com/forumdisplay.php?119-Present-Conflict-Vehicles-TMs
That has the lube order (oils and liquid types and capacities) as well as the TM's that will help guide you through everything.
theman10k
London
thanks its an early 6.5L GM 24v and yes checked most of them and getting nothin and it takes forever to start so trying new plugs before i start looking at the plug brains
