TedO
- 8
- 18
- San Diego, CA
Hello, I just found my M1008 doesnt start and I feel that the problem is the glow plugs arent working. The light still works, but it stays on for much longer than it usually does.
I checked the voltage to the relay and I read 24 volts (although I didnt disconnect all the glow plug leads.) Looking closer at the relay, it looks like it is a 24 volt relay(???). Never noticed that before. I am just getting into this.
I am going to check the resistance on the resistors. If the resistors burned up, what am I looking at? Are all the glow plugs fried? How could this have been working for 2 years with a 24 volt glow plug relay?? I assume I am looking at replacing the resistors, replacing the relay, and new glow plugs. I am updating the controller card too. Anything else I should do? Is this just the tip of the iceberg??
