MarcusOReallyus
- 816
- 113
- Virginia
When a component on a circuit board fries, it's for a reason. Sometimes that reason is simply that the component failed. It happens. More often, it's because some external malfunction caused too much current, or a correct amount of current for too long, to flow through that component.
When you soldered the obvious fault on your circuit board, you probably just enabled the card to work so that whatever external fault existed could show itself again.
I suggest you NOT buy another GP card until you find out what is causing the problem.
