Glow plug harness question
Thumper580
210
Virginia
Will this work on my M1123 (200amp) alternator or did I piss $55.00 away? Thanks. HMMWV Glow Plug Distribution Box Interface Harness P/N: 12379865
Bulldogger
618
Quantico VA
View attachment 885376View attachment 885377
Digging up an old thread. Can anyone comment on whether the cannon plug on this part number (12379865) can be spliced into my existing engine wiring harness? I have an old smart box that has died and the connon plug is corroded on. The rest of the wiring is OK as far as I know. I plan to get the CamoTek box and am comfortable making the splice if this cannon plug will fit my new smart box. I have a very old glow plug controller box.
Bulldogger
618
Quantico VA
I did some more searching after finding the P/N in the TM. Looks like this won't work, too many pins. Maybe I could cut some off... (kidding).
BDGR
86humv
493
Texas
The eng. harness has a big center socket that gets corroded ...and its hot all the time with batteries hooked up.
I had one once that it was green with corrosion, so I cleaned it out, and then the socket hole was to large to make proper contact
with start box.....so I had a doner eng. harness and replaced the corroded socket with a good one....and spliced it in....otherwise, you would have
to change the whole eng. harness.
