taskunitbruiser
- 56
- 28
- Alabama
I installed a new Nartron TSU from Mac. Still occurs. What now?
The wait light quickly flashes off, but (depending on the ambient air temp) it will start because it is actually warm.If it has only been say 1 hour since fully warmed up you should not need glow plugs, does the temp register at all when this happens?
Is this inside the smart box?It may be some other issue like the run solenoid not picking up when the IP is at a particular temp.
I have not specifically looked for smoke, but I do not think it smokes. The wait light flashes unless the engine is completely cold. If 1 hour + then it has cooled enough to be a very difficult start. Long extended battery drain and starter engagement. With the cooler weather somewhere 2-3 hours plus and it has cooled to the point of working great again. Fires right up on 20-30F morning cold starts.Describe in detail the symptoms when it fails, does it try at all to fire? do you get smoke out of the tailpipe?
What is the IP?You might try tapping on the IP when it will not start with the run switch in run, then switch to start.
Remember to wait 90 seconds every time you turn the run switch to off before trying again.
Yes. I have both driven it to operating temp (via dash gauge) and let it idle to operating temp. Wait light quickly flashes if shutting it off after a warm up when restarting. This should be normal. The engine starts well if under, say, 30 mins [i.e. still hot]. That 1-3 hour mark, depending on ambient temp and just my estimate, is the troublesome timeframe. After that time, wait light stays on for maybe 10 secs and it starts beautifully.Are you getting this fully warmed up as in driving it?
Ok, I will be on the look out for smoke. What could cause an injection pump to work all the time except for when the engine is semi-warm?If you are getting fuel but the engine is not hot enough it should smoke when trying to start.
