Glow plug lead resistance
mead
Cold Spring, Ky
Hello all.
1028 was running great two days ago, started running rough intermittently, and now suddenly cranks but won't start. Wait light still comes on for 5-10 seconds when key turned on. Bled fuel filter and fuel looked good.
Following maintenance manual (TM9-2320-289-20.pdf) troubleshooting instructions (p. 2-65, arriving at step 3) I find glow plug lead resistance of about .75 ohms for all glow plug leads, less than the 1-3 ohm range specified. Is less resistance a good thing? Should I proceed to step 4, or replace glow plugs as instructed in step 3?
Thanks in advance for help.
mead
Cold Spring, Ky
I see the error of my ways. (first time ever). I was checking resistance on the glow plug leads themselves, not the glow plug terminals as the manual said. Glow plugs are fine.
