Glow plug replacement experiences
Milbikes
CT
We have had a pretty good cold snap here in CT. My 6.5 Suburban has not been happy. But the old M1008 started every day, although it took some cranking. So I used a meter to test resistance on my glow plugs in the truck. Put one lead on the spade, one on the block. I found four that showed as open, and one that showed 07.2 on the 200k setting. At that point I stopped testing and went and bought AC 60G plugs. I was prepared for the worst, but the first one came out really easily.....like it was not tightened fully. This was true for all of them. They all came out easy. I was telling the truck what a good truck it was (Instead of cursing like some vehicles get me to do). Put the new plugs in, and it starts like a champ.
I decided to check all the plugs I took out, inside the house where it was warm. That turned out to be a surprise.
The truck had six AC 13G plugs in it. Four of them showed 0 ohms.
One showed 07.2 and had a small hole burned in the side of the element.
There were two Wellman 6A843G070 plugs in it, both with 0 ohms reading.
So, it seems like only two were bad? Why were my readings different in the truck? I am guessing it is because the plugs were somewhat loose, and not making a good ground?
markg
hutto,tx
i test them two ways. test light clip to hot, probe the unplugged end of glow plug in the block, light the testlight? good glowplug. pull them out if they are open.(if you can), put 12v to them, see if they heat up, you will be surprised.
i also have had some break off. pull the injector and get the pieces out with a magnet. if you cant there is a 50-50 chance i will be expelled out the exhaust . if not i gets stuck in the piston and knocks like ****. hope this helps.
mistaken1
Kansas City, KS
If six showed 0 ohms reading aren't those six bad? The new Wellman 070 and AC60G glow plugs that I have read with my Fluke auto-ranging meter all showed between 0.7 and 1.5 ohms.
jwaller
19
Columbia, SC
don't use the block to test the GP, I always put 1 of my wire leads directly on the GP I'm testing and the other on the spade itself.
Milbikes
CT
Ohms law is....... Confusing me! Dohh! I was thinking like testing a light bulb...thinking 0 ohms was a good thing. I'll hook them up to a battery just to see what I get.
The truck sure does start really nice now. My Suburban is jealous...it has been resisting starting. The more I work on the M1008, the more I like it!
ralbelt
9
West Warwick, R.I.
CFISH. If you go to the top of the front page and click on the forum button, then scroll down to the CUCV section and click on that, then click on the CUCV FAQ ARTICLE and scroll down to FAQ'S the first question has your answer.
