Glow plug sequence question
pigpen60
127
foley/missouri
My question is what is the glow plug sequence? I don't crank the engine till the wait light goes out. But when the engine doesn't start I turn the key off and repeat. is this correct?
dmetalmiki
2,028
London England
Yes. My V.W. Polo will only start and run good after two heats In this cold weather. Sometimes it is good to Heat, crank breifly, Heat again, Away it goes. Same applies to a lot of deisels in the coldest weather. However, Repeated heats if required point to a time to change the glow plugs.
Skinny
488
Portsmouth, NH
I don't think you actually have to crank the first time out.
If it is super cold out (sorry for a non-scientific term here), you probably can turn the key on, wait a bit, turn it off, then turn back on again for a second cycle...then crank. Don't let the wait light fool you, when it goes out, the GP's are still on. Use the volt meter as an indicator of GP operation. When they are on, the voltmeter will be way down to the left. When the GP's turn off, you will hear a thud and the voltmeter will immediately jump up.
pigpen60
127
foley/missouri
I hear the glow plug relay kicking on and off, I just wondered how many on/off cycles and how long. if its cycling after the wait light goes out do you even need to turn key off/on? I just changed out my m1008's glow plugs and found the fire dept? had changed some/all, none of the old glow plugs were swelled and one was still the 3/16" spade and one wasn't plugged in.
1,178
If the key is on, it should continue to cycle.
chesapeake
Winston, Ga
In the past 2 weeks I have replaced my GP relay, GPs and batteries. If it is cold outside I have to wait for the clunk of the relay before mine will start. If I try as soon as the wait light goes off it will turnover but not fire off
pigpen60
127
foley/missouri
Chesapeake, mine does/did the same thing. I changed all 8 glow plugs and the connectors so Thursday morning its supposed to be 8 degrees so ill see what if it starts. Last time it was single digits it wouldn't fire off.
pigpen60
127
foley/missouri
Ok had to wait till Friday for the 8 degree temp. Its alive! I cycled the plugs twice and she fired right up. Im tickled ****less, didn't have faith but I do now!
