Brogman
- 3
- 18
- Noblesville, Indiana
I checked the voltage on the GP controller card connections, here are the readings I got.
Ignition switch off no voltage to connections: A,B,D,G,H,L,M
Ignition switch on:
A purple none
B light blue 12.6 volts
D dark blue none
G two wires pink and pink/black stripe 12.6 volts
H orange none
L yellow 12.6 volts
M two black wires 12.6 volts
Ignition switch to start:
A purple (the one I reconnected) 10.21 volts
Is this normal? Could my GP controller card have failed?
I have a New GPD-2B GP card that I put in and then applied powered to it but there was no green light on the card, so could this new card be bad?
I have not tried grounding the light blue wire to see if that will cause the New NAPA ST85 GP relay to work yet. I did jump the relay and it clicked I didn't see if it powered the glow plugs.
Any help by those of you who know this system well would be much appreciated.
Ignition switch on:
A purple none
D dark blue none
H orange none
L yellow 12.6 volts
