2deuce
- 188
- 63
- portland, oregon
This is a new one for me on glow plugs. I have had them not work, because of the card being burned, solenoid burned out, glow plugs burned, but I have not had them work and then quit and then work again in the same glow plug cycle. When they are off more than they are on the wait light stays on very long and I can here the glow plug solenoid go on and off. My first thought is the solenoid is bad, but maybe it is the signal to the solenoid that is low or inconsistent. The solenoid that is on there looks like a ford application starter solenoid. I'm going to check the voltage on the pink and black wire with the key on and if it's good then replace the solenoid unless any of you guys have another idea.
