I've got a problem with my glow plug system but i am unsure what it is-
here are the symptoms:
turn key, wait light comes on... stays on longer than usual and then i hear a click from the relay and eventually it goes off. i then attempt to start but engine will not turn... clearly the plugs haven't warmed.
after a few rounds of this, eventually i turn over fine and start (with some smoke) (cold temp- around 35 degrees)
some days however things will work normal on 1st try- wait light will go out, i'll start and she'll turn over without smoke.
does this sound like it's the relay, the glow plug controller card or the temp sensor?
(or maybe the plugs themselves?)
