Glow plug wait light comes on
joho
Bath, PA
My glow plug WAIT light comes on when I am driving. It comes on and off, sometimes bright, sometimes dull. What can cause this?
1,178
I would start with pulling the controller card out, and cleaning the contacts with a pencil eraser. See if that helps.
Warthog
232
OKC, OK
Use the troubleshooting section of TM 9-2320-289-20 to check the glowplug system. Page 2-62. Pargraph 15.
bevanet
Arizona
On my blazer, the mechanic installed some kind of a thermostat so that my glow plugs don't come on at all above a certain temp. It used to annoy me that they came on when the engine was started even when it was warmed up. It seems like the glow plugs last longer now too. The blazer glow plugs used to come on after the engine was running too. Are yours coming on when it is warmed up, or first started?
joho
Bath, PA
Sorry about the double post
I am sorry that I double posted the same question, that was not my intention. I hope that it didn't bother too many people. Anyway, if the wait light comes on, does that mean the glow plugs are heating up? The engine is at operating temp driving down the road, when the wait light comes on. I will pull the card out of the control and see if that helps. It has been raining for about a month straight, maybe it got some moisture in it
1stSarge
Mount Vernon, Ohio
The most likely culprit in this scenario is a lost connection to the temperature sensor. Either the temperature sensor is bad, or the connections to it are bad. Like Dog said, check the contacts on the card housing, with special attention to the yellow wire. Then check that same wire at the temp sensor. Make sure it is tight and clean. Make sure it has continuity.
There are other possible culprits, but this is what I would look at first.
mistaken1
Kansas City, KS
According to antennaclimber's glow plug theory of operation the problem could be an intermittent short in the wire from the light to the glow plug controller. Or as others have mentioned the control card could have issues.
WAIT Light control
The GPM provides a ground to the Wait light for a period of time determined by the internal
components of the GPM.
http://www.steelsoldiers.com/cucv/62477-gp-module-theory-operation.html
Iceman3005
97
Holt, MI
joho: I'm having a similar problem along with gen 2 light flickering, got too be a short under dash because my volts don't drop, so if your volts aren't dropping when light flickers then should be a short, not glow plugs energizing.
