Keith_J
- 1,315
- 113
- Schertz TX
The "multi" in multi-fuel meant use of Mogas in addition to diesel or jet fuels. Most true diesels just will not run on gasoline. And the 6.2 GM was never designed with that capacity as the injection pump is lubed with the fuel, gasoline would cause rapid wear.
When the Hypercycle was being fielded, there were many vehicles in the military fleet which were gasoline fueled. And most of the larger trucks (10 ton and up) as well as armor/artillery were diesel.
The 1980s introduced the "one fuel" battlefield. This is when the GM CUCV was selected to replace the Dodge CUCV (powered by a gasoline 318 CI V. Gasoline gensets were being replaced by much heavier diesel sets. And finally by the 1990s, the M2 burner used in field kitchens was replaced by a diesel/JP-8 burning Modern Burner Unit.
Nearly every multifuel truck has a yellow placard listing acceptable fuels. Since the injection pump on these engines is lubricated by engine oil, gasoline does not cause undue wear
