70deuce
- 121
- 43
- Franktown, CO
When starting my 1985 M998 the wait light would flash for a second and go out. Impossible to start when cold. It has a KDS protective control box dated I think Oct of 2010. Figured that was the culprit so I removed it, opened it up and Houston we have a problem. Look at what is called a MOSFET (definition to follow) closest to the 24volt solenoid. See anything wrong? The box has that funky fried smell to it also. Little surface corrosion on connections that I don’t think caused the problem. MOSFETs are cheap and readily available and I have 5 of this part coming. This thing is listed to be rated at 55V and 74A. Pretty significant specs. I just am going to replace the fried one and clean up the connections and see what happens. I know it’s better to go the the ESS box but for $3 and a little time what the ****. I will update the post when the parts arrive and the box is back in and tested. I never did any service on the start system i.e. disconnect a cannon plug without disconnecting the batteries it just stopped working. OK here is the definition of MOSFET courtesy of Wikipedia. Enjoy this one! The metal–oxide–semiconductor field-effect transistor (MOSFET, MOS-FET, or MOS FET) is a type of field-effect transistor (FET). It has an insulated gate, whose voltage determines the conductivity of the device. This ability to change conductivity with the amount of applied voltage can be used for amplifying or switching electronic signals. A metal–insulator–semiconductor field-effect transistor or MISFET is a term almost synonymous with MOSFET. Another synonym is IGFET for insulated-gate field-effect transistor. The main advantage of a MOSFET is that it requires almost no input current to control the load current, when compared with bipolar transistors. In an "enhancement mode" MOSFET, voltage applied to the gate terminal increases the conductivity of the device. In "depletion mode" transistors, voltage applied at the gate reduces the conductivity[SUP].[/SUP]
