Good air...no brakes. M35A2.
stampy
22
Henderson. NC
Oh, you might spray penetrating oil on the nut that goes into the wheel cylinder(on the brake lines) so it is easy to loosen before you even begin to jack up the truck.:wink:
Castle Bravo
Hundredaire Socialite
233
Arizona
I just used 6 jack stands.
Don't believe the TM when it says torque the brake line banjo bolts to 65 ft lbs. I broke one and it pretty much ruined my day.
rlwm211
19
Guilford, NY
I just finished straightening out my brakes and the wrench sizes are 3/8 for the air vent on the master and 3/4 for the cap itself. I would recommend checking any trucks master cylinder daily until you know the idiosyncrasies of that particular truck. In my case, I had to rebuild a wheel cylinder and the master cylinder. Now the thing stops on a dime....sort of anyways...actually it has great brakes..
Just remember to refill the master after either each wheel cylinder you bleed, or else after two; no more....
. Ask me how I know that.....
also, a coleman fuel funnel works great as a means in which you can pour that gosh darn expensive Silicone brake fluid into the master. Just put it in the hole straight over the master.....
canyon creek
washington california
anybody know how you can tell if the airpac is working, or if the secondary cylinder it impacts is working? i have a new master cylinder and i have everything bled but the brake pedal is still a little mushy and the brakes won't really stop the truck.
hndrsonj
Senior Chief/Moderator
359
Cheyenne, WY
Did you use a pressure bleeder or do it manually?
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
Did you bleed the air pack first?
