Good Cleaning agent?
chesapeake
Winston, Ga
I have a starter bracket coming in this week and I have been gathering up the bolts to install it. I have no idea the last time one was on it. I picked up the M8x1.25x20 for the bracket to block and it will not fit. It will go in maybe a 1/2 turn. I sprayed brake cleaner up there and nothing. I tried a 5/16 bolt and a M7. Nothing. The M7 made it maybe 4 turns. I am going to try to get some purple power in there tomorrow and some more brake cleaner. Anyone have any other ideas besides running a tap through it
Ted
1,172
Air gun.
Keith_J
1,316
Schertz TX
Try an old bore brush. Bronze. I keep my old, worn-out ones for this purpose. A worn-out .30 caliber one will work fine on this application. Run it wet with solvent, then flush with WD40 or the like.
EMD567
Driver for the Ga Mafia
47
Aiken SC
Get a piece of coat hanger wire, and make a small L on one end, so that the "L" will fit onto the bore. Push, rotate, pull, until nothing else comes out. Then clean with WD40, and chase the threads with a tap.
WEAR EYE PROTECTION...........
chesapeake
Winston, Ga
Thank you for all the suggestions. I will end up using them all when I get home. I have a ton of old bore brushes and a massive compressor. Eye protection is a definite. I need to degrease the underside. I am hoping to get it cleaned without having to drop the starter
MarcusOReallyus
811
Virginia
Brake cleaner evaporates too quickly for deep crud. If it's been open for.... (years?) it's probably got some pretty solid gunk in there. An engine degreaser would work better - let it sit overnight to really soak in.
I'll second the motion on the bore brush!
chesapeake
Winston, Ga
Not to mention my hand and arm felt like I had submerged them in ice water while using brake cleaner!!! I will report later tonight and let ya'll know how it is going
swbradley1
Modertator
1,612
Dayton, OH
If you have a pressure washer like my new one if you could get the wand close it is getting cleaned out. It cleaned off rust and crap that have been on my mower for over 20 years that my other wouldn't touch. It also takes paint off to bare metal and I'm not too sure it isn't cutting metal as well. ;-)
chesapeake
Winston, Ga
My neighbor has a steam cleaner I am going to use along with a degreaser to clean the engine undercarraige. It is just a matter of hooking it to the tractor and bringing it down
chesapeake
Winston, Ga
Rewrite,
I took a .30 cal bronze bore brush and twisted it in the threads. A haze of rust dust came out. I squirted PB blaster in there and worked it with the brush. I cleaned it with brake fluid. I then sprayed an orange kitchen degreaser in the threads and let it sit for a 10 mins. Then worked it with the bore brush again (I cut the tip of the brush off since the brisles were mashed down). Cleaned it with brake cleaner and repeated the degreaser (this time some of the brissles fell off and lodged in there). I trid to the bolt and only got a couple of turns. I took a M8 x 1.25 tap and through a combination of the tap handle, my hands and a pair of pliers, I got the hole cleaned. I would turn it till it became hard and then clean the hole and tap with brake cleaner. I would spray the tap with WD40 and go again. After three hrs, the bolt fit. I had to drop the starter a little to get the bracket on. I used all Grade 8/meteric equivalent harware. I put a lock washer on the bracket to block bolt and a washer and lock washer on the bracket to starter stud. I took it for a 20 min ride, but didn't have the time to check the install. I will check tonight and go pick up new starter bolts since these have been on without the bracket
