Good pedal without air assist, not with air assist
hughscpa
Coffeen, IL
I have done my searches and can't quite find an answer. I just recently had the brakes fixed and I had a couple bad wheel cylinders. Now I have great pedal when I have no air pressure but the pedal goes to the floor when the air is working. I can still get them to lock up when the air is on but the pedal is on the floor. I don't like that at all. Any ideas?
1,172
Did you vacuum bleed, pedal pump bleed or pressure bleed?
Pressure bleeding works great with dot5.
1,172
Did you do anything besides changing a couple wheel cylinders?
1,172
And did you start with bleeding the master cylinder, then the airpack, then the wheel cylinders?
1,172
Did you adjust the shoes as the TM call for? use feeler gauges?
hughscpa
Coffeen, IL
Okay, thanks, I will give it a try and let you know. It will probably be after the Holidays. You guys are truly amazing. Have a safe and joyful holiday season!!
bigmike
355
Dixon CA.
Borrow or build yourself a power bleeder. It's the best way to bleed the entire system. Also, as posted above, follow the protocol for bleeding.
