gmjunky87
- 0
- 6
- halifax, pa
I was wondering what would be the best replacement glow plugs for my m1008, bought it from a gov auction.
The Bosch glow plug part number is 80034.Don't use Wellman's (Diesel Rx) like the Wiki says, seems the preferred plugs are the ac60g's or the bosch ones, don't know the number"
OMG! I just realized why all the old timers always say do a search. I like ac60g's...congrats on your new vehicle.
AC Delco 60Gs all the way. Search for the Resistor bypass as well if you don't plan on using the slave receptical to jump start.OMG! I just realized why all the old timers always say do a search. I like ac60g's...congrats on your new vehicle.
That's how I pound all my nails.Otherwise it's like using a sledge hammer to drive a finishing nail!
Do you just add the red wire? Or do you remove, replace or modify something that is already there. I searched even just the titles, but this post has the best picture, the one you posted here.AC 60g's and here is a pic of the bypass resupplying the glow plugs with 12v. Follow the red wire at the top of pic.
You first disconnect the 24v resistor from the GP-relay. Then you add a 12v feed to the relay. In rabelts pic he added his feed from the 12v junction block. In my conversion i ran a 8ga. wire from the front batt. pos. Both are good methods. I also have the AC60G due to all the good reviews.Do you just add the red wire? Or do you remove, replace or modify something that is already there. I searched even just the titles, but this post has the best picture, the one you posted here.
Did you install the switch in the power lead for the glowplugs?When I initially did my GP bypass, the switch I got from NAPA couldn't handle the load. I installed this one, and it works perfectly
