Goodman Oil Cooler Lines
lincolntwilliams
Tacoma Wa
I can not get them threaded to the block on my m1008. They won't even thread to themselves... Is that right? I've seen folks with good success on here but I can't even get them started!
I'm using the same part numbers as listed here in other threads.
lincolntwilliams
Tacoma Wa
I don't know what the deal was but the female compression end of the Goodman line was not the right tread. So either I had some non-typical fittings on my truck or the parts were wrong/with the right part numbers. I could bend the stock lines in half and thread them to themselves but the Goodman lines I couldnt. Anyway I had a hose shop put new hose on the stock fittings like suggested above. If you need new lines I suggest doing the same.... Mine were $50.... The goodmans were $60.
