Got a new (M275 Tractor) project a few weeks ago
rustystud
3,370
Woodinville, Washington
It's funny you ask about an update as today is the first time I
have worked on it in over a month. I am in the process of rebuilding
a John Deere 450b loader as well, so I am taking a break from the
loader and working on the M275.
I got the rod bearings replaced and the heads on. Now I am cleaning parts
and putting the engine back together. I hope to have it running again by the end of the week.
The fuel tank is different on the M275
the cross section is smaller than the M35. The tank is different
because it has to fit under the cab.
Looking good "jacklegjim" ! I would run a Die-nut down those head studs though before you put the heads back on.
jacklegjim
Lebanon,Tennessee
The engine has spin on oil filter adapters with 13/16 threads.
Which oil filter should I use? It had the shorter black napa
filters on it but, I have lost the numbers on them.
I got the 1 5/8 coolant hose and turbo rebuild kit delivered to day
so maybe I will get to start it this weekend.
I have not got to work on it the past few days.
So I am not as far along as I hoped to be. Not much has changed
since the last pictures but, here are the latest ones.
Jim
rustystud
3,370
Jim
Go with the "WIX" filters. I need to look up the numbers though.
