- 1,511
- 1,178
- 113
- TN
I have seen pictures of cracked bell housing, broken alternator brackets, cracked water pumps, and air compressors and gears damaged. In my case the interface of the compressor and power steering pump opened up due to a loose bolt. Those pesky driveshafts need balancing. It's not worth driving without having this done. The vibration is a real issue and can cause $1000's of dollars of damage. In fact, it should probably be the first thing a new FMTV/MTV owner should do.
FYI- I could not get my fuel primer to work. I had replaced it with a NOS one last year. Pushed on the button 100 times. Nada. I was expecting the typical broken valve spring. Nope. A very small amount of gunk from the fuel tank did not allow the valve to seal at the lip. Cotton swab on the gunk, and was back in action.
