Got my new Redneckmaster 5 inch exhaust..
acesneights1
22
20
CT
We don't have time to do it right but we have time to do it again?
Time was not the issue, practicality was. It makes no sense to spend money on something I am going to rip back off very shortly. When I put the turbo on it will require something custom made and I will send it out for that as I cannot bend 4 inch ex pipe. It does not leak, just not the prettiest work I ever did but it wasn't worth redoing when I get my tank filled. Waste of wire and argon..:D
big block 88
17
Topeka/Kansas
Well Ace it will get the job done tell your ready to get the real deal done.
Sorry to hear about tts I knew when the site and steve cole started shairng a name it would go down hill. It seems to me that unless you are part of a click no-one will answer a question you have I have kind of given up. **** Nick doesn;t even own a truck anymoreaua
BlizzardX23
12
California
Alrighty...well...I've attempted to work on my welding skills (Oxy Acetylene)....they are coming along! Ace, yours are still a lot better than mine lol ;)
Gunfreak25
620
Yuma, AZ
So is a single 5" the recommended size for a NA 6.2 or will a single 4" do just as good? There seems to be a lot of debate on this, but the general consensus with diesels is the less back pressure the better.
acesneights1
22
20
CT
I would think 4 inch is more than adequate since most 6.5 TD's Dmax, PS, Cummins run them. In fact I would go as far as to say even 3.5 inch would be enough. I used the 5 cause I had it laying around and it was easy to make the Y pipe.
