I had my '08 at work last week to replace my brake hoses. Why did they spec DOT 5 brake fluid? $$$$$$ OW!
I got distracted at one point and bled the master cylinder dry. After I refilled and bled the air out AGAIN I went to refill my brake clean can. When I came back there was smoke rolling out from the back of the engine compartment. I immediatly thought "oooh sht I left the key on"! I ran to the cab and found the key sitting on the seat. I ran around again and disconnected the front battery ground. Then I blew shop air on the resistors to cool them off. No fuse links melted.
After some poking around I wacked the GP relay with a wrench and heard the clack of the contact disengaging. I can't imagine the damage this would have done if I had parked the truck at the store or something and walked inside. Whew! Of all places it did it at work with my fully stocked tool cart near by.
I pulled 2 glow plugs and the tips looked a little blistered. Kinda like when you heat steel too hot with a torch and it turns dull gray and flakes. That's a real bummer since I just replaced all 8 a couple months ago.
Just had to vent. I almost had a heart attack...
