GFB
- 1
- 18
- Northwest IN
The troubleshooting continues. The controller card is bad so I wired a momentary switch to get this thing going after I replaced the radiator. Truck wouldn't start at all, so I started probing around and found that the glow plugs are getting voltage any time the key is in the run position, even with the card removed and both pink/black and blue wires disconnected from the new ST85 relay I installed. How is this happening? Bad relay? I'm unsure of the voltage amount because my multimeter is currently hiding from me, but it's lights up a test light pretty good. I will update after I find the multimeter.
Also, truck turns over fine but won't fire. Its getting voltage on the pink wire going to the injector pump. I'll find a helper and will bleed the fuel line. Any other suggestions? These things are so simple I can't believe I can't get it to run. It ran fine before I tore it apart to fix the radiator. The only other thing I did was replace vacuum lines while waiting on the radiator.
