- 89
- 2
- 8
- Billings, MT
Well...Elton was a God send. He was able to fix several things...
1)No start...fixed...starter will need replacing someday. It works now.
2)Jake Brake...hi/low fixed
3)Air leak -identified leak...new fitting needed.
4)Tire leak...fixed(fixed two rims with loose nuts securing bead to tire)
5)Drive test good 20 miles
6)Dimmer switch - needs replacing
7)Winch test for all 3-winches good
Glad hands air test good...rear, 5th, front (no trailer supply)haven't identified yet.
9)Located future battery disconnect ... (will add to shut down all power to prevent future drainage)
10)Oil sender on oil pan needs to be changed
11)Front marker lights need new bulbs
12)Service all grease joints soon
13)Oil, Air filter, and hydraulic levels good
14)Took Elton too Shooting Blanks had a nlast...no charge. Thank you Kevin and Arnie...Andrew...JJ
15)Wishing my wife could see the smile on my face when the truck started.
![Cool 8) 8)](https://www.steelsoldiers.com/images/smilies/icon_cool.gif)
