mangus580
- 283
- 0
- Western NY
Dont feel bad about it Amy... I had my 1009 gel over this morning. Spent probably 4 hours getting it running again. Now I dont want to shut it off!!
I sure do Chuck, I sure do....ida34 said:You guys need a heated garage like mine.
If you gelled your fuel, you probably also waxed your fuel filter, change it!!!! Should work wonders.amy1009 said:Okay...well she hasn't started since I made it home
Agreed! It was when I changed my filter Monday, that I was finally able to get going again...surpdlr said:If you gelled your fuel, you probably also waxed your fuel filter, change it!!!! Should work wonders.amy1009 said:Okay...well she hasn't started since I made it home
Low sulphur caused lot of gelling problems when it came out years ago. I wouldn't be surprised to find the same for ultra low sulphur fuel. Go to your local fuel injection shop and get a bottle of Stanadyne Ice breaker. Treat the fuel with that. Also get some Stanadyne Proformance Formula Plus and use that in every tank. Should end any fuel related problem!! Been working for me for well over 10 years now.amy1009 said:You know - I am mostly still suspicious of the fuel...see I left Saturday morning, and the weather was cold - and she started w/no problems...then I drove it til she was low on gas and filled up at the Meijers station in Plainwell (W-MI) and it hasn't been right since. I've heard that other people have had trouble with this new ULSD in the cold, has anyone else?
